- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBR350
- Mark as New
- Bookmark
- Subscribe
- Permalink
We have a long house and with the router at the front and 3 satellites, the system doesn't seem to be daisy chaining them however, I'm not sure if i've done something wrong in the setup, but they are all connected to the router with progressively weaker signals
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Daisy Chain is automatic on Orbi AX systems. Based on placement to the RBR and RBS out in a line and how they are turned on will determine how they get connected in Daisy Chain layout.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR350
Thanks, I moved the first satelite slightly further away and it seems to be working much better
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR350
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
