- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Port forwarding stopped working on RBR750
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello, I have an Orbi RBR750 with the latest firmware V4.6.5.14_2.0.54.
Hi, I have a problem with port forwarding. It used to work but stopped working. I did not change anything, and I am not sure why this happened.
I have two internal servers with different ports that I have to be able to access from outside of my network. I have two forwarding rules configured, but I cannot reach either one of my servers anymore. Can you help me with this?
Thank you.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad you figured it out. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Good Luck. 📡
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Port forwarding stopped working on RBR750
Port forwarding typically relies on two concepts:
- Dynamic DNS. Because most customers are assigned IP addresses that may be changed by the ISP (without notice) at any time, it is customary to use a DDNS service to set up an internet name that will automatically update to the new IP address. Orbi supports only a couple of DDNS services (noip.com, dyn.com). If somehow the DDNS service is no longer correct, then they will not map correctly.
- Hosts being open to accept connections.
How about double-checking:
- That the ports are open to the internet by using one of the common testing web sites, such as https://www.grc.com/shieldsup
- Also verify that the public IP address reported by the web test matches what the IP address that is current in the DDNS service.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello, thank you for your reply.
Ports are opened and listening. I can telnet to both servers internally, but I cannot connect when I am outside of my network.
I tried to connect using the ddns service and the public IP address that I see in my Orbi control panel. I have the same results. No connections.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Open and listening is reported by a web site?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, I used it for years, with a previous router and Orbi. It stopped working during the last couple of months. I do not use it outside too often, so I am unsure when it stopped.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Any new changes on the Orbi system in last couple of months? When was FW last updated?
If nothing was changes on the Orbi system, possible a ISP issue.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for your reply.
I use NETGEAR Cable Modem CM1000.
I did not change anything major on my router for some time now. Maybe I added a couple of IP reservations for some of my new devices.
I followed your advice to unplug the modem and router and started as you recommended, but it did not help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
This is hard to get my head around:
- The two servers are on the Orbi Attached Devices page with the desired LAN IP addresses (that the ports are forwarded to).
- The two servers will accept a telnet connection from the LAN.
- The Orbi shows two ports being forwarded from the internet to specific ports on those two servers.
- The two servers accept connections on those ports from the LAN.
- Shield's Up! shows that those two ports are open to the internet.
- Yet, when a device outside the LAN attempts to connect to the public IP on one of those ports, "nothing happens".
Would you mind sharing which ports are being forwarded and what type of server they are (generically: Windows, Linux??... HTTP, HTTPS, FTP, media, telnet??)
How is the situation being tested? (When I set up port forwarding, I typically drop the WiFi connection on my phone, start the phone's WiFi Hot Spot feature, connect a laptop to the phone, and perform tests.)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for all your help. It was my mistake. It looks like location where I am now block ports that I am trying to use. When I tested it with my phone without any Wi-Fi, everything works.
Thank you everyone for all your help!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good Luck. 📡
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
