- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBK353 satellite alternates between solide blue and flashing white
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi there!
I have just gotten a Orbi RBK353, and got it up an running. The base unit is in my living room, one satellite is on the 1st floor, and one satellite is on the 2nd floor.
Now, the 2nd satellite will always just go from flashing white into solid blue, then start flashing white again, go into blue, and so on.
Anybody has any solution to this?
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK353 satellite alternates between solide blue and flashing white
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 wrote:What Firmware version is currently loaded?
Hi!
FW on the NG router is 4.3.4.7_1.9.53 and on the satellite it's 4.3.4.7.
The modem from my provider (Vodafone) is labelled Arris Touchstone TG3442DE.
I'd estimate the distance (beeline) between the router and the 1st floor RBS is about 12-15 feet, and the distance between the 1st floor RBS and the 2nd floor RBS is around 15 ft. Of course they're all separated by solid concrete walls.
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Concrete and steel will impact wifi signal and coverage. Not sure if the 3 series system will be good enough to work thru concrete.
Also your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 wrote:Concrete and steel will impact wifi signal and coverage. Not sure if the 3 series system will be good enough to work thru concrete.
Couple of options,
Thanks for this.
I had Wifi disabled already as I have run an Amplifi HD system before.
I asked Vodafone to set the modem to bridge mode, but they said it will take a week for the changes to take effect...?
For now I've set the Orbi to AP mode instead of router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Dumb question: how would I set the Orbi back into router mode? I can't open its UI from 192.168.1.1 when it's in AP mode...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Look at the host routers connected devices table. The RBR should be listed there with a IP address, use this IP address to access the RBR in AP mode.
