- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBK752 - Phone constantly changing between nodes
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have an orbi pair and my Samsung phone keeps changing constantly between nodes. Is there any way to make it so it's less sensitive to changes between signal strength, and will therefore stay connected longer?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK752 - Phone constantly changing between nodes
Please post about this over inthe Orbi AX forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is this the only device that experiences this?
What model is this device and what OS is loaded on your device?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Armor, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Change CTS to 2347. Save settings and reboot the router and satellite(s).
@asperber wrote:I have an orbi pair and my Samsung phone keeps changing constantly between nodes. Is there any way to make it so it's less sensitive to changes between signal strength, and will therefore stay connected longer?
