Orbi WiFi 7 RBE973
Reply
RBK853 setup
Calvin1
RBK853 setup
I have my home setup using an Orbi rbk50 if I want to change to Orbi rbk853 how can I set it up so all of my current devices connected to the rbk50 will automatically connect to the rbk853?
Message 1 of 2
Guru
Re: RBK853 setup
The best way would be to set up the 8 series router to use same SSID name and PW that you use on the 50 series. You can connect the 8 series router to your modem and reboot the modem. Leave the RBR50 online while the 8 series poweres ON and comes to ready. Once it's ready, power OFF the RBR50 and your devices should migrate and connect to the RBR850 system. You can move the ISP cable to the RBR850 while setting it up. Once it's setup and up and running, should be able to just turn OFF the RBR50.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 335 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
