AMW1's avatar
AMW1
RBR750 Firmware 4.6.8.2_2.1.9 Slow Download
My orbi is running with a very slow download speed. Internet provider reported that they are providing internet without any issues of download speeds up to 600 mbps. I have had no issues for 1 year with this system and have had speeds slow down substantially for the last week.
I performed a reset on the orbi and am still facing slow download speeds. This is impacting my VoIP calls. Has my orbi gone bad?
What can I do to resolve this?
Download speeds are down to 9.34 Mbps and upload speeds of 22.62 Mbps
  • What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?
    Are you connected wired or wirelessly to the system?
    What are wired speed results with a wired PC and Ooklas installable speed test app?
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
    What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Do you have Armor, Smart Parental Controls, or Traffic Meter enabled.
    • AMW1's avatar
      AMW1
      I chose not to use the service provider's modem. I use a Netgear CM1000v2.
      Orbi is wired to the router. Should get speeds up to 600 Mbps. Wiring in my laptop to the orbi isnt even giving me a connection.
      Home size is 2200 square feet. Satellite is within 30 feet.
      • AMW1's avatar
        AMW1
        Wired does work now. 16 Mbps download 17.66 upload
