- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
RBR850 Requires Daily Reboot to Get Normal Connection Speeds
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hey Furry and all,
Sorry, not WAN. It was a conflict between the router and modem. My modem was (still is) at 192.168.0.1 and my router was at 192.168.1.1. That is where the problem was. I went to 172.16.0.1 for my router, changed all my static IPs to fall under that, and lett DHCP assign the others normally. All is happy!
I will be closing this post as solved, but I actually solved it, so how can I do that?
Thanks annd stay safe!
sky
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR850 Requires Daily Reboot to Get Normal Connection Speeds
the .0.1 and .1.1 would not be a conflict. Something I use periodically on occasion when I put two routers on the same line together.
I forgot what modem model you had. Are you still using the Arris SB8200? If so this modem uses a 192.168.100.1 to access it's web page only. Other than this, the modem will pass thru a ##.##.###.### WAN IP address to the RBR. Just making sure the information is correct about the modem your using. There shouldn't be any conflict for this or any modem only units.
Glad its working now.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Furry,
This is done. No more. I'm finished.
Thank you!
sky
- Mark as New
- Bookmark
- Subscribe
- Permalink
Enjoy.
- « Previous
- 1
- 2
- Next »
