astonmartinv8
Aug 10, 2022Aspirant
RBR850 plus 2 x RBS850 satellites- 1 satellite cycles flashing white and solid blue light constantly
Hi There,
I wonder if the community can help.
I recently purchased an RBK852 pack (1 x RBR850 and 1 x RBS850) PLUS an add-on RBS850 satellite (which was not part of the original pack). Firmware is V4.6.3.16 on all devices.
I have set it all up and it works. When I did this I had to factory reset all of the devices. The app and the orbilogin web access can see all three devices and all are working. However, the light on the add-on RBS850 constantly cycles through flashing white light and solid blue. Performance does not seem to be affected as multiple devices are connected to it (most by wifi and one wired). It is plugged into an 8 gang surge protected power strip.
I did look online and saw one thing on reddit, which suggested you generate a new backhaul password and this may clear it, which I did. I then re-synced the devices and the same problem recurred on the add-on RBS850 satellite.
Any thoughts into how I might resolve?
Thanks,
Marcus.
Sort By
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡What happens if you swap RBS with each other?
- astonmartinv8Aspirant
ISP modem is a TP-Link Archer VR1600v.
Property is a single level 3-bed apartment, about 1750 sqft, sort of rectangular. Router is in the middle and about 30-35ft from each satellite. 2 x glass windows and fair bit of concrete wall between each in each direction.
I haven't swapped the RBS but will try that. Good point.
One thing I am wondering is whether I actually need a second satellite.
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.For that size of home ya, having the RBR along with two RBS maybe too much wifi: https://youtu.be/UR0viMLISz4
I would turn off one RBS ane reduce the transmit power on the RBR from 100% to 50%. Under Advanced Tab/Advanced Settings/Wireless Settings
