Orbi WiFi 7 RBE973
Reply
RBR850 unable to change LAN setup
JPT34
Follower
Context:
Router: RBR850
Firmware: V4.6.14.3_2.3.12
Satellites: 2
Satellite type: RBS850
Router mode: router
DHCP: On
Model: RBK852
Problem: unable to save any changes on the web admin LAN setup page, e.g. DHCP ending IP address, reserved IP addresses
Results:
400 Bad Request
This server does not support the operation requested by your client.
Searched: "cannot set fixed IP address" "set fixed IP address server error 400 Bad Request" and read through all the posts
Tried:
* FF & Edge
* all suggestions and resolutions in search results; no joy
* reboot router
* reserved device name less than 20 characters
* reserved device name no non-alphanumeric characters, e.g. -
* no reserved IP addresses, only change DHCP ending IP address
Any assistance would be greatly appreciated.
Thanks
Message 1 of 3
Guru
Re: RBR850 unable to change LAN setup
Be sure to clear out all browser caches before entering the routers web page.
Try a factory reset and setup from scratch. Don't load any saved config file from back up.
Message 2 of 3
iyang
NETGEAR Expert
Hi @JPT34 ,
Can you share the screenshot for reserve Lan setup page ?
Thanks
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 296 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
