- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBRE950 Firmware Update problem
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I have an RBRE950 router with two satellites, all working fine except that the check for firmware update fails. On Advanced/Administration/Firmware update it gives the Status as 'Service Unreachable'.
My Firmware is V6.0.3.85_3.1.15.
Cheers,
- Pasta
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Furry,
I'll try that next time I can power cycle without the family moaning. It's purely a web server issue, all devices are actually on the new subnet so its not causing any operational problems.
I'm still curious why it won't find the firmware service but my guess is it'll be cured by the next formware update anyway. No need to stress out on this, I'll just keep my eyes open for firmware updates for the 950 series.
- Mark
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBRE950 Firmware Update problem
There is nothing newer currently.
What browser are you using?
Can you capture a screen shot of what your seeing?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Furry,
It's a standard Cox box:
Panoramic Wifi Gateway
Brand: TECHNICOLOR
Model: CGM4140COM
I'm using Microsoft Edge. The screenshot is attached.
- Mark
- Mark as New
- Bookmark
- Subscribe
- Permalink
I should add, I cannot update via the app either.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It is probably useful to ask if this is the only time that goofy error message has appeared?
i.e. Always before it came back with "No new firmware"?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
@Psychopasta wrote:
Hi Furry,
Brand: TECHNICOLOR
Model: CGM4140COM
- Mark
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi again Furry,
I've always seen 'double NAT' as a benefit, not a problem. I've used it for ages in all my previous Wi-Fi installations. What problems does it cause?
- Mark
- Mark as New
- Bookmark
- Subscribe
- Permalink
I should add that I have only the Orbi plugged into the ISP router, so there are no other devices connected to it. -Mark
- Mark as New
- Bookmark
- Subscribe
- Permalink
Nope, it has NEVER come back with that message...always 'service unavailable'.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Maybe however maybe a problem here that is inhibiting the RBR from checking with NGs update services. I had someone else check there 9 series since I'm at work and they told me there able to get thru on there system.
The suggestion of trying option #2 would be a trial test to see if that helps the RBR get thru to NG services.
Double NAT really isn't recommended as it can cause problems. Yes it may work for some and that fine if you want to run it like that. Just be aware that not everything may work seemlessly in this configuration. As this maybe one item that shows this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well, that is indeed a puzzle. Could you do a small experiment and do a DNS lookup on http.fw.updates1.netgear.com ?
On Windows the easiest way is to open a command window (We old-timers called it a "DOS Window") and type in
nslookup http.fw.updates1.netgear.com
Could you also comment on which DNS servers are being used by this system:
- Those provided by the ISP?
- Specific DNS servers that you chose?
You are correct that thousands of internet users employ a "Double NAT" because so many of them unbox their new WiFi system (Asus, Google, Linksys, eero, TP-Link.... or Netgear), plug them into their ISP box, read the WiFi credentials off the product label, and "off they go". Many do not even rename the SSID or change the password. They never know.
Internet search will turn up specific situations which Double NAT impacts. Things like:
- Forwarding ports to internal servers.
- Running OpenVPN to reach the router when away from home.
- Certain internet gaming.
People who run into a Double NAT issue generally discover it when something they are trying to do doesn't work and they do a search for probable causes.
I have a second Netgear Orbi that is 'behind' the primary Orbi. That is, definitely a Double NAT. Yet, when I open Firmware Update on that second router, it comes back with "no new firmware".
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello @CrimpOn,
C:\Users\markg>nslookup http.fw.updates1.netgear.com
Server: UnKnown
Address: 10.0.0.1
Non-authoritative answer:
Address: 104.119.67.89
Aliases: http.fw.updates1.netgear.com
http.fw.updates1.netgear.com.edgekey.net
The DNS was set to 'Get Automatically from ISP' and so I tried using 68.105.28.11 and 68.105.29.11. This make no difference to the nslookup or to the Firmware Update status.
I'll try disabling the NAT on the Cox Box.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Interestingly, I can ping the updates link just fine:
C:\Users\markg>ping http.fw.updates1.netgear.com
Pinging e70.g.akamaiedge.net [104.119.67.89] with 32 bytes of data
Reply from 104.119.67.89: bytes=32 time=18ms TTL=55
Reply from 104.119.67.89: bytes=32 time=20ms TTL=55
Reply from 104.119.67.89: bytes=32 time=19ms TTL=55
Ping statistics for 104.119.67.89:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 18ms, Maximum = 20ms, Average = 1
I tried a couple of other sites, and nslookup failed but ping succeeded.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is this with the RBR in the modems DMZ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I don't know. This is with the Orbi plugged into the modem and no changes to the setup of either.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try the DMZ or IP pass thru function on the modem for the RBR. Disable after testing.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yep. I'm going to disable the NAT on the Cox Box first, as that was your first advice which I haven't actually done yet 😁
- Mark as New
- Bookmark
- Subscribe
- Permalink
DMZ can be a quicker test as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I tried DMZ and it had no effect, so I rolled it back.
I am still surprised that I can ping the update server but not nslookup it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
BTW I also tried using Google's 8.8.8.8 DNS servers with no luck either.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you reboot the RBR after you set and applied the the DMZ configuration?
Let us know if bridging the modem works or not...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Oooh, I did not. Let me do that now.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Bummer. Reenabled DMZ, rebooted Orbi and the update service is still unreachable.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Psychopasta wrote:
Hello @CrimpOn,
Server: UnKnown
Address: 10.0.0.1Non-authoritative answer:
Thanks for doing the DNS experiment. When the Orbi looks for new firmware (two times each day), it makes a sequence of connections to the Netgear firmware server and does a DNS lookup before every connection. (That is how some users block their routers from doing automatic updates. They sign up for an account with OpenDNS and use an OpenDNS feature to block that URL.)
In your case, it appears that the web site is reachable.
I neglected to ask if the system has been restarted. (Not factory reset, just powered off and back on.)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, it rebooted when I changed the DNS settings
I guess I'll just chalk this one up to the Gods of the Internet having fun with me and do my updates manually 😁
Thanks to you and Furry for your help,
- Mark
