steve37066's avatar
Jun 14, 2022
RBS350 - Continuous resynching
My satellite continues to re-synch itself at irregular intervals.
Firmware is V4.4.0.10.
Router is RBR350 running the same version of firmware and is running in AP mode.
I have tried changing the WiFi channels to see if that helps but unfortunately there isn't any improvement.
Satellite starts flashing white led which then becomes fixed blue for 3 minutes before switching off. Then after a short period its starts the same sequence.
Router and Satellite are only about 15 feet apart.
Any help appreciated
Steve
  • KevinLiT's avatar
    KevinLiT
    NETGEAR Moderator
    Hello steve37066,
    I understand your RBS350 is constantly syncing and is only 15 feet away from the router. Lowering your transmit power to 50% can resolve this issue. To change your transmit power please follow the instructions below.
    From the router login home page navigate to the following:
    • "ADVANCED"
    • "Wireless Settings"
    • "Transmit Power Control"
    Best,
    Kevin
    Community Team
    • steve37066's avatar
      steve37066
      Tutor
      Hi Kevin,
      Thanks for replying,
      Have reduced transmit power to 50% for both 2.4 and 5GHz channels but the problem persists.
      Any other ideas?
      Steve
      • KevinLiT's avatar
        KevinLiT
        NETGEAR Moderator
        Hello Steve37066,
        Thank you for the update!
        Please check your PM.
        Best,
        Community Team
