- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBS750 ethernet port not working
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBS750 ethernet port not working
Power OFF and back ON?
Using good quality LAN cables? CAT6 is recommended.
MIght contact NG support to see what your options are if nothing helps...
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have Already tried that. Same result
- Mark as New
- Bookmark
- Subscribe
- Permalink
Press the reset button for 15 seconds then release then resync. Check the LAN ports.
Sounds like a HW failure on the RBS...
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FoReVeRJsUs wrote:
I have tried that as well. What is weird is that the lights are on for while and then after they turn off. No IP address assigned or device connected on the network
Note that it is normal for the LED right light to turn off after displaying solid White during startup: https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-router-and-satellite-mean. However, it is not normal for the ethernet ports not to work with wired devices. Have you tried multiple types of devices (to rule out an ethernet device misconfiguration)?
If you have a PC or laptop can you give us more detail on exactly the error displayed for the ethernet device? For example (1) Is the port able to get a valid IP address (not 169.254.*,* which is what it says when it cannot get an IP) but still cannot talk to the gateway (RBR), or (2) no IP address is received, indicating a DHCP error. On Windows the CLI to run is `ipconfig` and on Mac it is `ifconfig`: https://itssc.rpi.edu/hc/en-us/articles/360001995831-How-to-find-your-MAC-Address-for-MacOS-Linux-Wi...
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
LAN ports get enabled automatically during boot up. There's no user configuration.
