- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBS750 satellites show backhaul status out of sync
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have Netgear Orbi RBS750 Router with 2 satellites (Bought from Costco). I see sometimes one of the satellite goes into out of sync status in the backhaul. I am using the latest firmvare version V4.6.3.16_2.0.51.
I tried to look at the answers before, tried to restart and reset the satellite. Is there a setting to adjust?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBS750 satellites show backhaul status out of sync
What modem/gateway is it connected to?
Firmware on the router and satellites?
What is it showing for sync status?
How far from the router are the satellites?
How big is your home (sq ft)
what are the interior walls made of in the home (some materials block wifi better than others)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is WMM enabled Under Advanced Tab/Advanced Settings/Wireless Settings
- Mark as New
- Bookmark
- Subscribe
- Permalink
Home size is ~2750 sqft.
Distance between router and satellites is more than 30 feet and the walls are standard sheetrock walls.
Yes the setting is enabled for both 2.4 and 5GHz bands.
By the way backhaul status when it shows under the "Advanced | Attached Devices" show good sometimes, out of sync is intermittent.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try moving the RBS just a bit closer. Maybe 5 feet?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Check your firmware on each satellite. I had one that did not update to .16 firmware and it was exhibiting this behavior, but now works after I did a manual update to it. You should be able to see it in the web app or just log into the IP address of the satellite directly.
