- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
RBS750 vs PSV-2020-0432
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBS750 vs PSV-2020-0432
@FURRYe38 wrote:All this is in review with NG. The CBR750 is awating the field release of v3.2.17.##
Zero information on when that will be forth coming.
I would recommend the user to contact NG support to ask about testing a beta version if one maybe available to check out.
Netgear has replied and told me I am using the wrong firmware version. They said I should be using 3.2.16.6, not 3.2.17.x.
The problem is solved in the sense the CBK752 kit is on it's way back to Amazon for a full refund.
The Orbi CBK40 kit is back in place, workling quite well, and I am amazed how much faster pages load with working DNS - it's like having a new computer - I hadn't realized just how much the issue was disrupting things. Sure, the slower backhaul is an unfortunate side effect, but I'm getting nearly 600Mbs over it, occasional droops to around 500M -- since I can always drag a wire, it's not a huge setback.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thats fine. NG said it has been resolved and will be forth coming to the CBR750.
Good Luck though.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Actually - Netgear has been mum on the DNS issue. At least to general customers like myself. Same goes for the backhaul speed issue, the log issue, the remote management issue, and while some may think email and port forwarding port numbers are meaningless, they are important and it's why the settings are available. If I open port 40000 and use the HTTPS protocol there, the router should not allow a port 443 request through to port 443 just for the heck of it - yet the CBR750 does.
My last communication from them regarding my 02/28 request for help was on 03/10: they had this to say -- and nowhere did they mention anything was a known issue nor that an update could be expected that would resolve an issue.
NETGEAR Support
2021-03-10 13:36:41
Let us try to re-flash the firmware of your Orbi system. Re-flashing the firmware means manually upload the same firmware version you have on your Orbi system. We will still be using the latest firmware we have on our support site which is the firmware version 3.2.16.18. Please refer to the links below for the said firmware.
1. Orbi router (CBR750) firmware version 3.2.16.18
https://www.netgear.com/support/product/CBK752.aspx#download (Orbi Router) Firmware Version 3.2.16.18
2. Orbi satellite (RBS750) firmware version 3.2.16.6
https://www.netgear.com/support/product/CBK752.aspx#download (Orbi Satellite) Firmware Version 3.2.16.6
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- « Previous
- 1
- 2
- Next »
