- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBS850 is now V4.6.8.2 however latest firmware on support is 4.6.3.16???
- Mark as New
- Bookmark
- Subscribe
- Permalink
My RBR and RBS 850 seem to have a higher firmware than what is posted
I believe the V4.6.8.2 was either auto updated or an iphone app usage updated to V4.6.8.2
What is truly that latest firmware as of 16May22?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBS850 is now V4.6.8.2 however latest firmware on support is 4.6.3.16???
- Mark as New
- Bookmark
- Subscribe
- Permalink
There are numerous (very long) posts on the forum describing how firmware V4.6.8.2 was pushed to some users and caused them to lose access to both the Orbi web interface and the Orbi app. Netgear pulled V4.6.8.2 and is testing firmware that does not create this problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Are you experiencing any problems with v.2 loaded? If not, don't downgrade. NG is aware of the issues and has a patch that seems to be forth coming for those that can't access the RBRs web page after there systems were updated. This only effects those users. If your system is working and is accessible, leave it alone for now.
If your system is not accessible and you don't want to factory reset it, contact NG support with your product serial number and they'll fix it for you.
