Orbi WiFi 7 RBE973
Reply
Rbr750
sethm1
Guide
Rbr750
I have a Netgear orbi mesh network. Model number rbr750 with 2 satellites.
have a Wyze outdoor camera with a base station.
Via a Ethernet cable the Wyze base station will ONLY work/connect to the router.The Wyze will NOT connect to either satellite. Why? And it used to!
Message 1 of 4
Phyber
Luminary
Re: Rbr750
Have you reset the Wyze? I have a Wyze for indoor use that I use on occasion and it connects just fine with no issues via WiFi to the Guest Network, which is renamed and has its own pw.
Message 2 of 4
sethm1
Guide
Re: Rbr750
 I’ll try that next. I also have the Arlo net cams with also its own base station.
I ended up moving the Arlo to Orbi satellite and then the Wyze station back to Orbi router.
all working now. Guess that will have to do.
Message 3 of 4
Phyber
Luminary
Re: Rbr750
We have two motion Ring cameras and a Ring doorbell, all on the same Guest Network and they work fine.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 474 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
