- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Re: RBR850/RBS850 internet dropping from wireless clients
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes I agree this was frustrating that the firmware updates are not checked properly and we end customers face all these issues. Looking at the log files the DHCP is constantly changing IP addresses which is resulting in dropped connections. So finally had to spend money and get the Eero 6 Pro AX4300 and its been great. Seemly installation and no issues ever since. Sad had to move away from Orbi brand. Hardware is great but have consistently seen software is buggy
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Changes made: v4 FW
Turned off AX for 2.4
CTS set to 2347
Domain Name Server (DNS) Address - Use These DNS Servers
and set all devices to have Reserved IP addresses
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/New-RBR750-RBS750-Firmware-Version-4...
If you haven't already, you might update FW as well:
Since updating mine, I have not seen these issues.
