Oct 12, 2023Guru
Share your Orbi 3, 7, 8 or 9 series system UpTime
Found on the routers and RBS IP address/debug.htm web page for best details, please post both RBR and RBS uptime. Please note of any inconsistencies between the RBR and RBS. Generally the RBR and RBS uptime should be same. Home wide power brown outs should be noted if these are seen.
Thank you.
Sort By
Will be hitting 30 days of good uptime on my RBK853 system with v.15 FW loaded. Been good and solid.
I can't say anything about IPv6 as my ISP doesn't support it natively so I can help there.Otherwise, been good for me.
Anyone else have good up time on this version of FW?
31 plus up days on this version of FW for the 854 series. Working good.
Off to check on a different system now.
Anyone with 960 series Orbi systems out there, could you please post the CPU, Memory usage and system uptime from the RBRs IP address/debug.htm web page please?
- claudiutApprenticeRBR 750:
Basic Information
Firmware Version: V7.2.6.21_5.0.20
Boot Loader Version: V1.0.14
seal: v2.1.5.49-0
seal_services: v2.1.5.20-0
armor-bd: v2.2.100.3
spc-circle: v3.31.1.2
CPU Load: 29.73%
Memory Usage(Used/Total): 353 MB/874 MB
System Uptime: 16 days 06:29:35
RBS 750:
Basic Information
Firmware Version : V7.2.6.21
CPU Load : 17.01%
Memory Usuage(Used/Total) : 305 MB/874 MB
System Uptime : 16 days 6:34:47
Hop Count : 1RBK963 System
Basic Information
Firmware Version: V7.2.6.21_5.0.20Boot Loader Version: 2016.01_rtm-5.0.1.32
seal: v2.1.5.49-0
CPU Load: 14.13%
Memory Usage(Used/Total): 369 MB/818 MB
System Uptime: 7 days 00:15:31
RBR 850:
Basic Information
Boot Loader Version: V1.0.13
seal: v2.1.5.49-0
CPU Load: 11.27%
Memory Usage(Used/Total): 446 MB/874 MB
System Uptime: 28 days 20:54:06
RBS850 #1:
Basic InformationFirmware Version :V7.2.6.21CPU Load :13.7%Memory Usuage(Used/Total) :325 MB/874 MBSystem Uptime :34 days 21:38:32Hop Count :RBS850 #2:Basic InformationFirmware Version :V7.2.6.21CPU Load :7.11%Memory Usuage(Used/Total) :800 MB/874 MBSystem Uptime :34 days 21:42:16Hop Count :1- spewakLuminary
