- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Speed Test Issues
- Mark as New
- Bookmark
- Subscribe
- Permalink
Speed Test Issues
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Speed Test Issues
Netgear has created a highly organized, but not intuitive community forum. In addition to the original Orbi forum, there are also forums for the LTE products, the Orbi Voice, the Pro, Orbis with internal cable modems, and.... (drum roll) the Orbi AX line.
There is a chance that posting the question in the Orbi AX forum will attract the attention of someone who owns the AX and watches that forum. (I say a chance because I do not have an AX Orbi and never open that forum. Have no idea if posts get responses quickly, or ... not)
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
That said, I believe you are correct: With a single gigabit port on the CM1000v2, the absolute most speed that can be achieved is just under 1gb.
Is that historical SpeedTest graph from the Orbi? (My sad old 'original Orbi' has no option to display past results. Would be cool to have that feature.)
I'm sure you realize that a lot of factors outside of the router can affect internet speed. If you decide to dump the Orbi because of this, what would replace it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I don’t know why the speeds have dropped - I’ve tried factory reset.
I have been impressed overall and the satellite station with 5Ghz dedicated backhaul has improved WiFi throughout the house. As it’s under warranty I’m hoping to get replaced with the same.. assuming this is a faulty device and not an issue in newer firmware etc. Earlier speed tests when new this year were just what I’d expected
- Mark as New
- Bookmark
- Subscribe
- Permalink
Netgear has set up a community forum specifically for the Orbi AX product. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
Test your speed with a wired PC and Ooklas installable speed test app instead of Orbi app.
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I was surprised to see this post which appears to indicate that the Orbi Speed Test (by Ookla) does not match the regular Speed Test by Ookla.
As my internet feed tops out at 230mb, I am in no position to explore what the heck is going on.
- Mark as New
- Bookmark
- Subscribe
- Permalink
All speed tests are improved with that older firmware regardless of if you use apps, router, wired or wireless.
I hadn’t really noticed by my lan internet speeds all dropped to around 600Mbps after the 4 firmware. Reverting back had everything running blazing fast matching the speeds that come directly off the modem.
Netgear need to fix this bad firmware and give users a better way to downgrade. God help anyone who’s not an engineer. Going back to the oldest version to get telnet support, disabling auto update and then bringing everything back up at the router and modem to the latest stable version is not for your casual user. Thought I’d bricked my satellite several times but hopefully all is good at v3.2.18.1 - I will not be upgrading automatically again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please contact NG support and let them know what you experienced.
Glad you got it working again. Be sure to post about any Orbi AX, support, information or issues in the Orbi AX forum.
Enjoy.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I know this is nothing to do with you and not personal but that’s outrageous. This is clearly a FW issue. I have a device less than 12 months old that cost in excess of $500 and now I need to pay a premium to report a problem (which the hundreds of other comments verify NG don’t have a solution for) 🤷🏻♂️
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
ALL USERS of the 7 series Orbi AX system, please contact NG support by opening a support ticket and contact NG and ask them for the beta that seems to be avialable for the 7 series that seems to be directed to fixed what everyone with a 7 series has been having problems with:
https://www.netgear.com/support/#
For user out of warranty, contact @Blanca_O and @DarrenM and send them a PM and ask for the beta.
Good Luck.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I signed up for the forums just to find a solution to this problem.
I have a Orbi Router RBR750, after the update to V4.6.3.7_2.0.49, my wifi speeds are down to 20mbps, but I have 600mbps internet. I did confirm the satalite gets the correct bandwidth over the backbone, but not to the connected devices.
Not sure how to contact a person to get the beta firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
