- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Streaming issues with RBR350 (constant buffering and pixelation) when using Chromecast
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have two satellites and in general most things seem to be okay, but the issue I'm having is that if I stream via Chromecast it constantly keeps buffering and I get low bitrate streams.
I've turned defender off and checked for the latest firmware, but it's not fixed the issue.
Can anyone help???
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Streaming issues with RBR350 (constant buffering and pixelation) when using Chromecast
It's a small house and I get a really strong signal in the other room, but for some reason the Chromecast seems to be throttled in there and I have no idea why?
I never had these issues with my old router it's only started since installing the Orbi
- Mark as New
- Bookmark
- Subscribe
- Permalink
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Is any of the following enabled?
Armor, Smart Parental Controls, or Traffic Meter.
- Mark as New
- Bookmark
- Subscribe
- Permalink
For anyone else having similar issues, I am 12+ months on with still zero solution.
What I have been able to find via searching around is that Chromecast dongles don't support upper range 5ghz WIFI channels and the RBR350 for whatever bizarre reason does not allow you to change the 5ghz channel.
Basically if you own a RBR350 and your TV does not natively support Chromecast and you have to buy the USB dongle then you're stuck with 2ghz WIFI and a poor signal.
Very disappointing from both Netgear for not allow people to change the 5ghz channel on this model and Google for not allowing their products to connect to higher 5ghz channels.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Does anyone know anything else I can try? I am on the verge of cutting my losses and just throwing this system in the bin and buying something else.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Hard to help you out if you don't give feedback to the question presented...
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
