- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
TLS Error: TLS key negotiation failed to occur within 60 seconds when trying to use Orbi VPN"
- Mark as New
- Bookmark
- Subscribe
- Permalink
Trying to use the VPN services on my Orbi RBR850 router, I followed these instructions (https://kb.netgear.com/25389/Enabling-VPN-service-on-a-NETGEAR-router-using-a-MAC-OS-computer) but I once I try to connect through tunnelblick I just get "Waiting for server response" and the vpn won't connect, I'm not sure what to do
I'm on firmware version V4.6.9.11_2.3.5
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: TLS Error: TLS key negotiation failed to occur within 60 seconds when trying to use Orbi VPN&quo
- Mark as New
- Bookmark
- Subscribe
- Permalink
Updated firmware and vpn still wont connect, keep getting this error
address: [AF_INET]98.197.101.6:12974 (allow this incoming source address/port by removing --remote or adding --float)
2023-07-25 01:19:26.805046 TCP/UDP: Incoming packet rejected from [AF_INET]192.168.1.1:12974[2], expected peer address: [AF_INET]98.197.101.6:12974 (allow this incoming source address/port by removing --remote or adding --float)
2023-07-25 01:19:56.943516 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
2023-07-25 01:19:56.943678 TLS Error: TLS handshake failed
- Mark as New
- Bookmark
- Subscribe
- Permalink
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
