Orbi WiFi 7 RBE973
Reply
Two PS5s lagging when both in use with Orbi RBR750
HalomanZero
Follower
So I have two PS5s in the house, and an Orbi RBR750 with two satellites. PS5s are wireless and cannot be hardwired. Problem only occurs when both PS5s are turned on. Either work perfectly fine when the other is off regardless if it's completely off or in rest mode.
Orbi firmware is v4.6.14.3
Message 1 of 2
Guru
Re: Two PS5s lagging when both in use with Orbi RBR750
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the distance between the RBR and the two PS consoles?
How many RBS are deployed?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices? Test the game consoles connected wired to the RBR to see if this problem continues.
What channel configurations are currently set on the router?
Armor, Smart Parental Controls or Circle, Traffic Meter.
Is IPv6 enabled or disabled?
Set NAT Filter on the RBR to OPEN under Advanced Tab/Setup/WAN Setup.
Your behind on FW as well:
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/New-RBR750-RBS750-Firmware-Version-...
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 108 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
