Orbi WiFi 7 RBE973
Reply
WiFi dropping every day. Only reboot helps
alternet
Tutor
Hi all,
I do have a problem with my RBR850. Since a few days it is constantly dropping WiFi: on the router everything is OK - no issues but no device can connect getting stuck at "getting IP address". Only reboot helps for a few hours.
RBR850 has 4 satellites.
Attached screenshots shows the architecture (of course screen illustrates satellites as disconnected since I just rebooted the router and they need up to a few hours to get connected back - this is also very annoying). Usually there is about 100 devices connected to this WiFi. Guest network is also up and running (quite often it is not possible to connect to the guest network). VPN not activated on the router  - used only by connected by LAN PCs. Activated IoT network but not used yet.
I need to reboot the router each day - how to solve this issue? Please help me since I helpless.
All firmware is up to date (1x RBR850: V7.2.6.31_5.0.24, 2x RBS850: V7.2.6.31, 2x RBS350: V4.6.14.3)RBR850 WiFi issue.png
Is it time to change my router to another one?
Message 1 of 13
Guru
Re: WiFi dropping every day. Only reboot helps
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
What happens if you turn OFF the RBS350s?
Armor, Smart Parental Controls or Circle, Traffic Meter.
Message 2 of 13
CrimpOn
Guru
Do you know when the firmware was updated on the router and the two 850 satellites?
There have been many posts on the forum from users who have the 350 satellites connected to a 750 router and "things went bad" when the 750 was updated to version 7 firmware.  The consensus on the forum seems to be that the version 7 firmware is not compatible with the 350 router.  When users returned the router firmware to the previous version (prior to v7), their systems worked again.
If this situation developed immediately after the 850's firmware was updated, my first thought is that the 850 has the same incompatibility.
Message 3 of 13
alternet
Tutor
I always update the equipment as soon as new updates is published - I know now it is not too wise.
These were updated months back in the pas ....seems not to be related to the new version of firmware since my problems started days back in the past not months.
Message 4 of 13
alternet
Tutor
@FURRYe38 wrote:
==> I am not sure. I do have a a fiber optic modem without access to it. The modem is connected with RBR via LAN cable.
==> ~4800 sq ft + I need to cover part of the garden.... another ~5000 sq ft
==> RBR and RBSs are connected via LAN. The distances between them are about/up to 100ft. It is not a problem with WiFi coverage.
==> Nope. The problem is only with connecting to WiFi. Lan devices work perfectly.
2.4GHz Auto 8
5 GHz 36 + 40 (P) + 44 + 48
==> did not try so far.
==> Need to find time for it since to many dependencies is there.
Message 5 of 13
Guru
@alternet wrote:
Let us know the model # of the ISP modem or ONT when you get a chance.
For this size of home, only two RBS would be needed. I have a 5000 sq ft home and only use two RBS. I can get away with one.
How are the RBS ethernet connected to the RBR? Directly behind the RBR or is there any LAN switch or LAN Patch panel in between them?
What CAT# lan cable is used to connect the RBS to the RBR? CAT6 UTP is recommended here.
2.4GHz Auto 8
Try channel 1 or 11 on 2.4Ghz. Try 48 on 5ghz.
Please turn the 350s OFF for now.
Ok.
Message 6 of 13
alternet
Tutor
...it seems I got what was wrong. I deactivated IoT WiFi and it is stable for now. The only problem remains with RBSes ....the satellites do not want to connect.
Message 7 of 13
Guru
The RBS850s are not connecting?
Message 8 of 13
alternet
Tutor
nope.
Not connecting, ....sometimes connecting after a few hours, sometimes connecting after the satellites are rebooted, sometimes after the router is rebooted, ...
Today for instance got connected once the router started up…. But I do not have a clue why the router got restarted in the first place (the same was yesterdayorbi 1.pngorbi 2.png)! Real need to replace this Orbi by something more stable - any suggestions?
Message 9 of 13
Guru
Need to turn OFF the RBS350s.
How are the RBS ethernet connected to the RBR? Directly behind the RBR? Or is there a LAN patch panel or LAN Switch in between them?
Message 10 of 13
alternet
Tutor
everything is thru a patch panels - cables and patchpanels are in Cat 6A (one is via ptachcord Cat 6)...
3 RBSes are connected by patch panels directly to the RBR and one is via switch (Cat 5e - but this is the one with Cat 6 patch cord).
Message 11 of 13
Guru
Lets disconnect the patch panel cabling from the back of the RBR that leads to the RBS350s. Turn them off.
Then lets reboot the RBR. I'd power OFF the remaining RBS850s for 30 seconds then back ON. Lets see if these get reconnected.
Message 12 of 13
Guru
@alternet
Any progress on this?
Message 13 of 13
Top Contributors
Discussion stats
  • 12 replies
  • 1301 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
