Orbi WiFi 7 RBE973
Reply
block wifi on schedule on RBR750
KG_RBR750
The schedule is not working; it did before, but I'm not sure if it was before firmware update to V4.6.9.11_2.3.5
I want wifi to be blocked from 11:15pm to 6am every day. I checked to be sure time/dst is correct.
Thoughts? Thank you.
Message 1 of 8
Accepted Solutions
Guru
Re: block wifi on schedule on RBR750
Message 2 of 8
All Replies
Guru
Message 2 of 8
KG_RBR750
Thank you - I guess I should roll back to previous firmware? How?
Message 3 of 8
Guru
You can if previous FW version worked.
What version had you been using?
Same way as you manually update FW. Download the files to a PC and send to the RBS/RBR web page. RBS first then RBR lastly. Though you might leave the RBS were there at and just downgrade the RBR. RBS should continue to work after the RBR is downgraded.
Message 4 of 8
KG_RBR750
I don't know which firmware was the last; it upgrades automatically (or I check and allow). I'm going to guess 4.3???
Sorry, I don't understand RBS/RBR...
Message 5 of 8
Guru
You might try v4.6.8.5.
I would avoid going any lower then that.
RBS = Satellite
RBR = Router
Message 6 of 8
KG_RBR750
got it! thanks very much!
Message 7 of 8
Guru
Let us know how it goes please.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 809 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
