- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
can not add MAC address in Access Control list for RBK752
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
My wifi is Netgear Orbi WiFi RBK752 AX4200.
Hardware Version RBR750
Firmware Version V4.6.5.14_2.0.54
I am setting up MAC address filtering in the Security / Access Control.
Problem Scenario 1 :
i.) Check checkbox "Turn on Access Control" to enable buttons in "View list of allowed devices not currently connected to the network"
ii.) click "View list of allowed devices not currently connected to the network" to display the list
iii.) click "Add" to display "Add Allowed Device" page and add a MAC address and then click "APPLY" to confirm change
iv.) when adding 38th MAC address
the system prompt "orbilogin.com didn’t send any data."
and then the system NOT showing this newly added 38th MAC address
then after reboot the router, I only can find 29 MAC address, i.e. losing 10 MAC addresses previously added
v.) I then can add back some losing MAC addresses back to the list but problem repeat
*** sometime this kind of problem happened when I have just adding 2x MAC addresses.
Problem Scenario 2 :
vi.) check a checkbox to select a device in the list, click "Remove from the list" and then click "APPLY" to confirm change
vii.) but found the device still exist in the list even performing delete for several times
Query :
BTW, what is the Maximum number of MAC addresses can be added to the list of allowed devices ?
Thanks a lot
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: can not add MAC address in Access Control list for RBK752
There maybe a limitation on how many you can input in to this section. I've asked NG to see that this limit is.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I don't think it is causing by a limitation, is it application software bug instead ?
as if it is a limitation, I encountered the problem when only entering 2x entries in the list, it is too low and not enough, even a common TPLINK can support up to 64 entry.
