- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
2.0.1.4 firmware
- Mark as New
- Bookmark
- Subscribe
- Permalink
2.0.1.4 firmware
I have the previous version. Should I change to this one? What features are gained or lost?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: 2.0.1.4 firmware
Going to 2.0.14 from the 2.1.2.18 release, you would lose wired Ethernet backhaul, and support for the Orbi outdoor satellite. If you need neither, you could downgrade,
Whether you should depends on your circumstance. If you're having issues, you might want to try. If not, I would not bother. 2.0.1.4 in my environment is not without problems, but appears to be the best version I've tried (and I've tried many versions so far).
- Mark as New
- Bookmark
- Subscribe
- Permalink
What changed between 2.0.0.74/76 and 2.0.1.4?
EDIT: Looks like it added KRACK protection over 2.0.0.74 and addressed a satellite memory leak.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
No. 2.1.2.18 was released before 2.0.1.4. 2.1.2.18 was pulled and 2.0.1.4 takes its place. 2.1.2.18 is only newer from the context it includes "newer features."
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well if I am running 2.1.2.18 should I switch?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Landerx
If you are not having issues with the 2.1.2.18 firmware then no reason to switch. 2.1.2.18 Does have Disney circle and Ethernet back haul and the 2.0.1.4 does not.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
@webminsterwrote:No. 2.1.2.18 was released before 2.0.1.4. 2.1.2.18 was pulled and 2.0.1.4 takes its place. 2.1.2.18 is only newer from the context it includes "newer features."
My fault, you are absolutely right - I somehow missed that 2.0.1.4 was released on the 14th.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
