- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
AT&T Uverse Cable Not Working With Orbi RBK50 (AC3000)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: AT&T Uverse Cable Not Working With Orbi RBK50 (AC3000)
Here's where I'm at with all of this...
My contract period with AT&T actually ends next month. Not only am I having all these issues getting the Orbi to work as intended...Xfinity came in a LOT ($137 for 150 MBPS) for less ( than AT&T ($180 for 100 MBPS or $224 for 1000 MBPS) for all my services! Next month I'm switching to Xfinity.
Re: Disney Go parental control
I would need to put the Orbi back into router mode to check this. Internet was running good today with Orbi being set to AP. If I start having problems again I'll be switching back to Orbi in router mode which will enable me to check this.
Re: Isolating Uverse Cable to Direct Input of Pace and All Other not on Pace
I have various equipment in each room...and one ethernet cable from the router to each room (hence the GS108's in each room). This just isn't possible with my setup.
Re Buying a Cable Modem so I can Control All Boxes Myself
Xfinity totally allows customers to do this. When I switch over to them I'll also install my own modem. I just need to pick a modem. Below are the compatible options which Xfinity lists on their website. Your thoughts re which to pick?
Modem + Gateway
ARRIS SVG2482AC
Netgear C7100V
ARRIS TG862G
ARRIS TG862R
Modem Only
Netgear CM500V
ARRIS TM822R
ARRIS TM822G
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, you'll need the Orbin in router mode for Circle support
No way to segment the PACE stuff from the other devices?
Modem + Gateway
ARRIS SVG2482AC
Netgear C7100V
ARRIS TG862G
ARRIS TG862R
Modem Only
Netgear CM500V
ARRIS TM822R
ARRIS TM822G
I would ask ComCast/Xfinity if they suport any of the modems metioned here if possibe:
Arris SB8200 https://www.amazon.com/dp/B01N6SKK1G
Netgear CM1000 https://www.amazon.com/NETGEAR-CM1000-D ... ar+cm-1000
Motorola 8600 https://www.amazon.com/Motorola-MB8600- ... orola+8600
24 channel Netgear CM-600 https://www.amazon.com/NETGEAR-download ... rds=cm-600
16 channel Arris SB6183 https://www.amazon.com/ARRIS-SURFboard- ... rds=sb6183
These should be supported...
Gateways - routers/wifi >> NOT recommend - you should have a modem and a separate router. This is preferred. <<
- « Previous
- 1
- 2
- Next »
