- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Alternative ways to troubleshoot instead of just downgrade FW in case of issues
- Mark as New
- Bookmark
- Subscribe
- Permalink
We have here in the community are very "active" user who suggests for all kind of issues a firmware downgrade.
But there are a lot of users using the latest FW (for RBK50 2.7.2.104) without any issues.
The latest FW also contains several important security fixes.
see: https://kb.netgear.com/000062883/Security-Advisory-for-Multiple-Vulnerabilities-on-Some-Routers-Sate...
The network (device) is the entrance to your home, therefore you should secure it as good as possible.
Below, you find some steps you can do without the need to setup your system from scratch. Mainly when your system has worked fine before and you encounter issues after a FW upgrade or your system became unstable without any (config) changes from your side.
I've done a factory reset and reload from config successfully more than once on different firmwares.
- save the router config to a file via the web GUI (you can do that also before a FW upgrade, but also take a config save before doing the following steps)
- power OFF the router and all sattelites for 1-2 minutes
then power on the router first and wait until startup is complete (approx. 5 minutes)
check webGUI and check if internet connection is working
then power on one sattelite and wait again approx. 5 minutes until startup is complete
check if the sattelite is connected to router (wifi or cable) via Web GUI
do the same with the remaining satellites - if step 2) does not help, proceed with the following steps
power off all sattelites
reset the router to factory defaults
setup router and load the previously save of the config
wait until the router is fully initialized (approx 5 minutes)
then power on one sattelite and wait again appro 5 minutes until startup is complete
do the same with the remaining satellites - if step 3) does not help, proceed with the following steps
reapply the same firmware and repeat all steps from 2) - if step 3) does not help, proceed with the following steps
downgrade the firmware - if issues are still not fixed, reset the router and do the setup as described in step 3)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Alternative ways to troubleshoot instead of just downgrade FW in case of issues
Nice.
Along with thise, should help get users thru the problems:
Thank you for posting this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
some facts:
- 1 thread, 8 answers, 4 from the same user (with no added value)
- there are at least 2 actual posts in other threads, where a factory reset helped
https://community.netgear.com/t5/Orbi/Orbi-DNS-and-DHCP-and-NTP-Broken/m-p/2071538/highlight/true#M1...
https://community.netgear.com/t5/Orbi/RBR50-2-7-2-104-firmware-Issues/m-p/2071667/highlight/true#M11... - I have some minor mistakes in the opening posts and to clarify, I should add a final step
this part:
5. if step 3) does not help, proceed with the following steps
6. if issues are still not fixed, reset the router and do the setup as described in step 3)
should be changed to:
5. if step 4) does not help, proceed with the following steps
7. if issue still exists, try to find help here in the community
As I cannot edit the initial post, I'm thinking about opening a new thread with the updated instructions.
And there I hope we get posts/answers which are related to the initial post.
- Mark as New
- Bookmark
- Subscribe
- Permalink
No one will consider your advice of any value as long as you continue to turn this into a food fight by posting such as
IMPORTANT ADVICE:
please ignore posts from user vajim.
He is just acting like a bad troll here in the forum.
Unfortunately the moderators are not taking any actions against that.
act civil and you may get the results you desire
