Orbi WiFi 7 RBE973
Reply
Attached devices sync to internal DNS
Pierre1256
Initiate
Hi,
I have a question concerning the "attached devices" menu.
When I look to the menu, I think that this is the Netbios name, not the DNS name.
Is there a way to automatically get the devices name from my internal DNS server (a Synology) ?
I don't want to have to re-enter all my devices information.
Model: RBK33| Orbi Plug-In WiFi System
Message 1 of 3
Accepted Solutions
CrimpOn
Guru
Re: Attached devices sync to internal DNS
There is no chance that the labels in "Attached Devices" come from DNS.  By default, Orbi gets DNS from the Netgear servers.  Some Community members recommend substituting Google DNS (or others).  99% of Netgear's customers have no personal DNS server.
Orbi makes some guesses based on the MAC address about who the manufacturer is and makes a guess as to what "type" of device it is and these guesses are often way off the mark.  (My Sony phone showed up as a "Linux Device.")
There are three variables in the Orbi parameter list which contain the descriptions for device name, device model, and device type.  If you dump your DNS entries to a text file, it is possible to enter them into Orbi via telnet.  There is a Community thread explaining how to do this.
https://community.netgear.com/t5/Orbi/Quick-way-to-re-enter-your-IP-reservations-after-factory-reset...
(Read all the way to the bottom.)
Message 2 of 3
All Replies
CrimpOn
Guru
Message 2 of 3
Pierre1256
Initiate
Thank you very much !
I find what I was looking for.
Regards
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1231 views
  • 3 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
