Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Bad speed tests when using Orbi RBR40 WiFi
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-02-12
01:32 PM
2021-02-12
01:32 PM
I have an RBR40 router
I have Verizon fios gigabit service
When I connect to the Verizon WiFi I get speeds of down 377 up 286
When I connect to the Orbi router WiFi I get speeds down 93 up 92
Hardwired to the Orbi (no WiFi) I get up speeds down 920 up 940
Why would the the WiFi specs off the Orbi router be lower then the Verizon router. Any suggestions on what to do or how to reconfigure everything?
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-02-12
03:11 PM
2021-02-12
03:11 PM
Re: Bad speed tests when using Orbi RBR40 WiFi
Are you running the routers at the same time?
Message 2 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-02-12
03:22 PM
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-02-12
03:54 PM
2021-02-12
03:54 PM
Another thing to check is which band you're connected to.
the orbi does bandsteering and 2.4ghz is much slower than 5ghz.
Are you connected to 5ghz during testing?
Message 4 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-02-12
05:12 PM
2021-02-12
05:12 PM
@Dgfamilypa wrote:@vajim I am, I have the verizon router with wifi on and the Orbi with wifi on but we only connect to the orbi. My understanding is we have to use the verizon router as the Modem
If you don't need the Verizon router get rid of it
if you run both one has to be the router while the other is a access point
Message 5 of 5
Announcements
