- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
CBK 752 Blinking white Upstream
- Mark as New
- Bookmark
- Subscribe
- Permalink
The Upstream light is blinking on my Orbi CBK 752. How do i correct that?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: CBK 752 Blinking white Upstream
do you have a copy of the cable connections page?
That'll show the upstream/downstream data.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, bad/old/cheap connectors, or corroded connections. Replace them if you do.
If you can, simply connect the modem right where the coax comes into the home. This prevents wiring in the home from being the issue. And some ISP’s charge if the wiring issue is in the home. So this helps prevent this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
