- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
CBK752 - NETGEAR Admin - Attached Devices connected ORBI changing_220305
- Mark as New
- Bookmark
- Subscribe
- Permalink
I need to have your support.
On admin site, there are attached device list, but one of them is connected with far ORBI router so internet is quite slow.
How could I change the connect Orbi device on admin site? For example, ORBI Router to ORBI Satellite-1 device.
Can I do this?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: CBK752 - NETGEAR Admin - Attached Devices connected ORBI changing_220305
You can't.
Its the devices own built in roaming protocol that decides what to connect to.
You can do a few things to optmize/help it change
1. Make sure the router/satellite are at least 30 ft apart
2. you can change the router/satellite broadcast power. If the home is a bit undersized for the setup, your devices can just be choosing to connect to the router as their protocol says "its good enough"
3. you can try powering your device off and then back on. Sometimes, if the router booted up first, the device can connect to it first and stay connected even once the satellite is running because its roaming protocol isn't that agressive.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the distance between the router and 📡 satellite(s)?
Can I do this?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Wow, I guess we'll not find out the real resolution on this one...
