× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Can I add custom DNS entries for my LAN using Orbi?
jayessdeesea
Initiate
Hi,
I see where I can add custom entries to DHCP (MAC address to IP address). This is great, and probably good enough for what I'm trying to do.
However, I'm wondering if there is some feature that allows me to map a LAN IP Address to a hostname.
I've got a bunch of computers on my network like network attached storage, linux servers, and the like. I'm getting tired of typing in the IP Address all the time
I'd rather browse to https://ds916.orbilogin.net/ rather than browse to https://192.168.1.12
This is basically the orbilogin.com -> 192.168.1.1 mapping that Netgear provides. I guess I'm wondering if this is hard coded or if I can go in and add my own entries
Thanks
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 3
Accepted Solutions
TheEther
Guru
Re: Can I add custom DNS entries for my LAN using Orbi?
AFAIK, the Orbi doesn't have that support. An alternative is to use mDNS. Many O/Ses support this natively, including MacOS, iOS and Synology. For Windows, there are open source mDNS support. Or you can get it from Apple by installing Bonjour or iTunes (Bonjour is included; you can uninstall iTunes if you don't use it). For Linux, install Avahi.
Once you have mDNS installed, then the machines will typically be reachable via their machine name appended with ".local". For example, https://ds916.local/. I have an ancient Synology DS207+ which I can reach simply by entering "thebox.local/" into my browser.
Message 2 of 3
All Replies
TheEther
Guru
Message 2 of 3
jayessdeesea
Initiate
Thanks! Works great!
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 11360 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
