jrcruise
Oct 05, 2017Aspirant
Can't access/reset Orbi router after crash
My new Orbi RBR50 router has "crashed" twice since initial installation about 8-10 days ago. I was able to reset the router after the first event, but after the second, I am unable to access or reset the router. It displays a solid white halo light after restart and reset. When the system is working, it's great, but I've had two catastrophic failures within a few days of initial setup and am starting to worry about reliability.
1 Reply
Sort By
- DarrenMSr. NETGEAR Moderator
Hello jrcruise
I would suggest contacting support if the router keep failing they would be able to help or replace the unit.
http://www.netgear.com/support/contact.aspx
DarrenM
