- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Can't duplicate orbi app speed test results
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have an AC3000 system with an RBR50 and 2x RBS50's. I recently upgraded my service from 500 to 1gb. My ISP modem is naturally connected to the RBR.
When I test using the orbi app, up and down results are very close to advertised (before and after upgrade) but I can't get anywhere close with laptop connected via ethernet to either the RBR ports or even the ISP router ethernet using multiple test sites including speedtest/ookla. In some cases, a test using the speedtest app on my phone shows better results than ethernet.
What's really puzzling me is the orbi app reports close to advertised but when I test connected to the modem directly, the results are dismal. If it was the Orbi choking the signal on its broadcast I would think the ISP modem would be reporting similar to the orbi app results.
Is the test in the orbi app designed to get a pie in the sky result and perhaps my laptop and phone are challenging the connection more?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Can't duplicate orbi app speed test results
1. what actual firmware is on the router?
2. what ISP modem do you have?
3. After the speed upgrade, did you try a factory reset/reinstall (not using a backup)?
4. this is more of an fyi, the wireless on that router won't max out a gigabit connection. the wired will.
