- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Configuration for Wowway internet Cable
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have recently switched internet providers to WOW's 1Gbps service that came with their eero pro 6 mesh system. I have an RBR50/ 2 RBS50 I used with my old AT&T modem/router. My question is, can I use my Orbi with WOW's modem/router? Technicolor model #CGA4234VGW. If so, how do I reset and configure it to work with WOW's technicolor? Just a novice here lol
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Configuration for Wowway internet Cable
@Deus47 wrote:I have recently switched internet providers to WOW's 1Gbps service that came with their eero pro 6 mesh system. I have an RBR50/ 2 RBS50 I used with my old AT&T modem/router. My question is, can I use my Orbi with WOW's modem/router? Technicolor model #CGA4234VGW. If so, how do I reset and configure it to work with WOW's technicolor? Just a novice here lol
Page 39 of the Technicolor User Manual describes how to set the device into "router" or "bridge" mode.
In bridge mode, non of the Technicolor router functions apply and the WiFi capbility is turned off. The Orbi must be in router mode (the detault). All devices connected to the Orbi should continue to function as before.
The post did not describe how the Orbi is currently connected to AT&T. (router vs. Access Poiint mode.)
A question that was not asked is: "should I keep my Orbi, or change to the eero Pro 6 Mesh system"? The eero Pro could be set to the same SSID/Password (exactly the same) as the Orbi and all devices should connect to it. How many EERO's did they furnish?
Being a Total Computer Nerd, I would try out the eero Pro to see how it stacks up against the Orbi. i.e. Plug one in, walk around checking signal strength and performance. Then, plug the other in and repeat. What I would not do is rely on the Technicolor WiFi instead of the Orbi or eero Pro.
