Orbi WiFi 7 RBE973
Reply
Existing wifi router setup with orbi
AndySNZ
Orbi newbie here - just set up AC2200 3 pack - works fine but I’m plugging into existing modem/wifi router and still seeing “old” wifi as well as new one. 1 is that a problem and have I set it up wrong and 2. Could I improve the system by upgrading modem/router as well?
Message 1 of 5
CrimpOn
Guru
Re: Existing wifi router setup with orbi
Most people choose to (a) give the new Orbi exactly the same WiFi name (SSID) and password as the old WiFi router so that devices do not have to be reconfigured, and (b) log into the old router and turn off the WiFi.  If they ever want to unplug the Orbi, they can simply restore the WiFi on the old router, and everything will reconnect to it.
Also, it is generally felt that having two "routers" is not a good idea:
https://kb.netgear.com/30186/What-is-Double-NAT
Message 2 of 5
AndySNZ
Much appreciated - double NAT - at least I know it has a name 🙂 I’ll see if my ISP can get the modem/ router to “bridge mode” - I need to keep the original device because it has a VOIP phone running of it as there is no cell service here....
Message 3 of 5
Guru
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Message 4 of 5
timch
Luminary
Given the VOIP service I think your easiest way home is use option 3 above. You lose some of Orbi's functionality but you allow it to do what it does best in my opinion, provide seamless WiFi.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 775 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi WiFi 7
