Orbi WiFi 7 RBE973
Reply
Guest Network "guests to see each other and access my local network" option Not working
radracer
Follower
I have the RBR40, V2.2.1.210, and I have Guest Network enabled, but I do not have the checkbox set for "Allow guests to see each other and access my local network". However, when I connect to the guest network I CAN see everything on my private network. Why is this the case and how do I make it so that Guest can access my local network? This seems to be a bug. I have also checked and unchecked that box to see if that helped, but it did not.
Thanks in advance for any help.
Message 1 of 3
Guru
Re: Guest Network "guests to see each other and access my local network" option Not workin
How was the FW updated? Via Auto Update? I would try a factory reset on the Base unit then set up from scratch. Check the Guest Network accessbility features.
Message 2 of 3
AC641
Luminary
This is a known issue and has been reported on these forums many times.  Netgear seems in no hurry whatsoever to correct it.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 983 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
