Orbi WiFi 7 RBE973
Reply
How can I disable Netgear analytics on Orbi RBR50?
Nazly
Message 1 of 3
Accepted Solutions
yata001
Star
Re: How can I disable Netgear analytics on Orbi RBR50?
I think running the following command on the router should stop the analytics. Unfortunately, it has to run each time the router is restarted.
killall -9 aws-iot
Message 3 of 3
All Replies
CrimpOn
Guru
Message 7 in this thread: https://community.netgear.com/t5/Orbi/How-can-I-disable-Netgear-analytics-on-Orbi-RBR50/td-p/1737330
says Netgear Analytics cannot be turned off.  (At least at the time the post was written.)
Message 2 of 3
yata001
Star
killall -9 aws-iot
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1218 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
