Orbi WiFi 7 RBE973
Reply
How do you tell
Showguy
Virtuoso
How do you tell
How do you tell what devices are connected to either the router or the satalite?
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 1 of 2
timch
Luminary
Re: How do you tell
The router page will tell you all the devices that are connected to both.  It will also tell you the IP address of the satellite. If you then log into that IP address then the satellite will tell you the devices attached to it alone. Clearly you can repeat if you have more than one satellite.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2430 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
