- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
I get mad with password problems
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello everybody,
Relying on past experience with Netgear products, I expected a quick installation of my brand new Orbi system.
The start up of the router and satellite and their appairing worked quickly. The troubles began when I tried to login into the router, especially to set connection details to my ISP. I launched my browser (Netscape) typed in the 10.0.0.1 address and got a login window which said approximately "Authentification required. The site says 'NETGEAR Orbi'". and prompted to enter an id and a password. I confidently entered "admin" and "password" as usual, but it failed. I tried also "NETGEAR" and "Orbi", and also "NETGEAR Orbi" and "password" but all of these failed.
Supposing that maybe I had entered a password in the preceding start process, I tried to remember but I did not succeed.
Then I entered the "lost password" process. The system asks for the serial number of the router, which is written in very small characters under the router. I entered this serial number at least 10 times, trying to figure out if the B or the 6 were not a 8, and all sorts of variations, but the system kept telling me that my text was wrong and did not match the information written inside the router.
I tried also with a smartphone and a wired laptop, With no more success.
Then I gave up and removed all the Orbi system and reinstalled the former access point.
What is to be done ?
🙂 gabier
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes do a factory reset on the router and use firefox browser and navigate to 192.168.1.1 and the set up wizard will be waiting for you. Walk thru this wizard. Thats all that needed.
@gabier2 wrote:@FURRYe38 wrote:
Factory reset the Orbi router and connect a wired PC to the router and walk thru the setup wizard.
What is the Mfr and model# of the ISP modem?
OK, I will do this, but what is the "setup wizard" ? How do I execute it ? Does it come automatically after the factory reset ?
The Mfr is "Sagemcom Broadband SAS" (a french Mfr), it is let by my ISP (ORANGE) with the name "LiveBox 4"
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: I get mad with password problems
Did you walk thru the setup wizard and input a new PW for the admin account. This is one of the requirements during this process.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the same problem with the admin password access. The app was humming along fine for the past six months and then it asked me to provide the password login. I used the default password that came with the system and that has been used since I received the system, but it locks me out. When I go online to change it, it asks me security questions that I have never answered.
I rebooted the system, but no luck there. Do I have to do a new set up (I hope not as the first time around was painful).
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Walk thru the setup wizard and input a new PW for the admin account. This is one of the requirements during this process.
@dokG wrote:I have the same problem with the admin password access. The app was humming along fine for the past six months and then it asked me to provide the password login. I used the default password that came with the system and that has been used since I received the system, but it locks me out. When I go online to change it, it asks me security questions that I have never answered.
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sorry, case850, it was probably and old reminiscence. It was of course Thunderbird !!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
This orbi system drives me really mad :). My prefered browser is really FIREFOX.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 wrote:Yes do a factory reset on the router and use firefox browser and navigate to 192.168.1.1 and the set up wizard will be waiting for you. Walk thru this wizard. Thats all that needed.
OK, it works. In addition to navigate to 10.0.0.1 (my internet modem has the address 192.168.1.1) I had to empty theFirefox cache.
Then all happened as you said. The wizard indeed set up everything.
Thanks for help.
🙂 gabier
- Mark as New
- Bookmark
- Subscribe
- Permalink
You may want to use the modems DMZ for the Orbi router if your using the Orbi router in router mode. Helps with double NAT conditons.
Enjoy.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks. I did end up resetting and re-registering via Google Chrome. All seems to be functioning with the exception of the app able to do an Internet speedtest. I will consider Firefox if I have to do this next time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Seems the the mobile app is having problems:
Use speedtest.net app on android or iphone as a alternative speed test app.
@dokG wrote:Thanks. I did end up resetting and re-registering via Google Chrome. All seems to be functioning with the exception of the app able to do an Internet speedtest. I will consider Firefox if I have to do this next time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Case850 wrote:
The Orbi and Orbi Pro are Wireless Hotspot "box drop" products. In other words you just "box drop" the device in to provide quick Wi-Fi access with without the need for wiring. The downside of Orbi and Orbi Pro is their lack of reliability, performance and features.
Thank you for explanation. What do you mean with "The downside of Orbi and Orbi Pro is their lack of reliability, performance and features." ? About the features, I appreciate especially the Wifi network all over my home with the same SSID. Before, I must have multiple access points to overcome the concrete walls, but the downside was that the home wifi apps got lost in those different SSIDs. Now GORBI seems to do the same job quite better.
🙂 gabier
- Mark as New
- Bookmark
- Subscribe
- Permalink
