Orbi WiFi 7 RBE973
Reply
Intermittent disconnection of wifi after upgrading firmware to 2.5.1.8
pawan2003
Initiate
Hi All!
Ever since I upgraded my firmware to version 2.5.18, my wifi seems to disconnect frequently. This is particularly felt while using apple products. Also, my phone and ipad tend to connect directly to the router instead of the satellite located close by.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 8
Accepted Solutions
Retired_Member
Not applicable
Re: Intermittent disconnection of wifi after upgrading firmware to 2.5.1.8
@pawan2003 wrote:
Hi All!
 2.5.18 has issues....get rid of it
Why did you upgrade?
Message 2 of 8
All Replies
Retired_Member
Not applicable
@pawan2003 wrote:
Hi All!
Message 2 of 8
Guru
Above suggestions working:
https://community.netgear.com/t5/Orbi/Throttling-Devices-RBK53/m-p/1858561/highlight/true#M81925
https://community.netgear.com/t5/Orbi/Orbi-model-RBR50-keeps-dropping-connection-during-Zoom-calls/m...
@pawan2003 wrote:
Hi All!
Message 3 of 8
Retired_Member
Not applicable
factory resets are for loss password
Message 4 of 8
pawan2003
Initiate
Thanks! I downgraded the firmware to 2.3.5.30 and the network stabilized.
Message 5 of 8
Retired_Member
Not applicable
Nice work.
Tip:  If your system is working it's best to leave it alone.  NG will auto-push any that contain critical updates.
Stay safe.
Message 6 of 8
Guru
Next time, try a factory reset the next time you update FW and run into problems. Its a good trouble shooting step. My system is solid on v2.5.1.8 as is others.
You can try Voxels FW as well:
https://community.netgear.com/t5/Orbi/Voxels-FW-available-for-50-series-Orbi-only-available/m-p/1883...
Enjoy.
Message 7 of 8
Retired_Member
Not applicable
Enjoy.
factory resets are for lost password
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 874 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
