- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Internet Issue on RBR40 starting Daylight saving day
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please try a factory reset and setup from scratch with the RBR and RBS.
Power OFF The ISP Modem as well for 30 seconds then back on. Walk thru the setup wizard and be sure to write down all important information. Be sure not to enable Armor, Circle, Access Controls, QoS or Traffic Meter on the RBR.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Internet Issue on RBR40 starting Daylight saving day
my RBR50 time is correct
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello sanjeev40084,
I am sorry to hear you are having connectivity issues with your RBR40.
Please answer the questions below so I can assist you further:
1. Is the RBR40 in access point mode?
2. Which modem are you using?
3. Are you able to access the internet when you connect laptop or PC to the RBR40?
Looking forward to your response!
Best,
Kevin
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just checked and it is in router mode.
Spectrum Modem Model# ET2251
No.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Has Armor or Circle been enabled?
Has a factory reset been performed and setup from scratch?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@sanjeev40084 wrote:
Is factory reset only the solution? I got tons of smart devices which I will have to reset again to connect to my wifi if it works after the factory reset :catsad:
Generally you do not need to reconfigure or redo the setup for devices as long as you keep the same SSID and security setting. Many Orbi customers replace their old router with a new Orbi router, use the same SSID, and all their smart devices still work and connect to the new Orbi wireless network.
So factory reset your Orbi, setup its wireless network in the same way and using the same SSID, and then your smart devices should connect again automatically.
- Mark as New
- Bookmark
- Subscribe
- Permalink
