- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Is 2.1.3.4 in auto update.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I can confirm, we've begun pushing 2.1.3.4 available for auto-upgrade. Feel free to upgrade using mobile app / WebUI.
Orbi Product Management
However I check my Orbi it is not showing the update. Mine is still 2.1.2.18
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Is 2.1.3.4 in auto update.
Even after selecting for check update?
You can manually update as well. Please do a factory reset on both router and satellite(s) then set up from scratch if you upgrade the FW.
I recommend using IE11 or FF browsers for this. Be ethernet wired with the router and satellite when doing the update. Update the Satellite first, then router.
@OrbiMan wrote:
@AmitR
- Mark as New
- Bookmark
- Subscribe
- Permalink
For some reason, NG does not have v2.1.3.4 listed in the RBK53 product.
See http://www.netgear.com/support/product/RBK53.aspx#download
- Mark as New
- Bookmark
- Subscribe
- Permalink
Mine is not showing either (RBK53) and I have checked in the UI several times with different browsers.
Funny thing is it was showing several days ago and I just figured it would auto-update as per usual. However, they auto-update never did happen and now the UI shows no new firmware version. I'm still on v2.1.2.18, which is fine since I have zero issues with it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
They pulled the latest beta off the auto update list, which since it is a beta, I'm not sure why they put it on there in the first place. Thats also the reason it isn't available via the download page for the various models, its a beta.
I didn't have any real issues with 2.1.2.X, so I waited till 3 of my 4 devices had beta firmware available for them before I tried it out.
My RBS50Y is still on 2.1.2.20, but seems to be working fine with the rest of the things on the latest beta, 2.1.3.X
- Mark as New
- Bookmark
- Subscribe
- Permalink
@loomis1975 wrote:They pulled the latest beta off the auto update list, which since it is a beta, I'm not sure why they put it on there in the first place. Thats also the reason it isn't available via the download page for the various models, its a beta.
Yeah, my point was that it is just awfully strange that v2.1.3.4 appears on the download page for RBK50 but not for RBK53 nor RBR50. The only reasonable presumption is an oversight.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I think you are right. When they pulled 2.1.3.4 off auto update, they should have pulled it off the RBK50 product page as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Model Name | Device Name | Current Version | Status | |
Router | RBR50 | RBR50 | V2.0.1.4 | No new firmware version available. |
Satellite | RBS50 | RBS50 | V2.0.1.4 | No new firmware version available. |
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can find the links to the firmware here in this thread
https://community.netgear.com/t5/Orbi/Orbi-MR-2-1-Update-3-23-18/td-p/1533584
Right now the firmware is not on the auto update sever until the engineers agree it is completely ready to be pushed to all systems.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
@DarrenM wrote:You can find the links to the firmware here in this thread
DarrenM
Does Netgear recommend a factory reset after a auto-update to the new FW?
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you are experiencing issues yes I suggest a factory reset.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
