- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Issues With AX1800 Wifi Extender
- Mark as New
- Bookmark
- Subscribe
- Permalink
Purchased this today and after downloading the Nighthawk proceded through the setup. All seemed well then it said there was a firmware update that needed done. So I ran the update and it's not worked since. It doesn't even show up as available in the app or otherwise. It keeps telling me that it's my mobile device in the app. It doesn't show up when I check available networks with my laptop either. Any suggestions before I give up on it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Issues With AX1800 Wifi Extender
I resorted to resetting it. Twice!!! First time it then showed up again as an available network on the app. After repeated attempts to connect to the router and it telling me that the password was incorrect I reset it again. Apparently it will not connect to both the 2.4 and 5.0 ghz messes it up. After the 2nd reset I only connected to the 2.4 ghz band and all is well. Now if it only does what I need it to do which is feed an ethernet cable to another building.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Netgear has set up a community forum specifically for the WiFi Extender products. Most of the people who watch that forum are more likely to have experience with WiFi Extender products and know how to work it better than those of us who follow this forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/bd-p/home-wifi-range-extenders
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the reply. I will look there but to be honest I'm done with Netgear. This is the 2nd time I tried one of their products and had issues. I've installed two TP-Link routers now and the last one just this past week. What a breeze! 5 minutes and it was setup and running perfect. The Netgear WiFi extender is offline this morning. I don't want or need a product that needs costant baby sitting to keep on line. The extender was working when I went to bed. It doesn't even show as available this morning even when I check available networks with my laptop.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Maybe something that isn't compatible with TP-Link products.
Good Luck.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The other product was a new Netgear router 2 years ago. Devices constantly had to be reconnected because the connection was lost. Thanks though. WiFi is WiFi. It shouldn't matter what make the source is. Just like the firmware update disabling it last night and havine to reset it to make it work again. Ease of use should be priority 1. I'm relatively tech savvy but this is not pleasing me with how difficult it is to make work.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the distance between the router and extender(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
What channels are you using on the main host router?
