Singularity2030's avatar
Mar 09, 2019
Lost all LAN connections RBK50 - both router and satellites
Last night, with zero configuration changes, all LAN ports stopped functioning on both the router and satellites.  I had a switch plugged in to the router so I tried bypassing it with some direct connections.  None of them show a connection.  I've rebooted a few times and even updated the firmware manually with the latest .32 version.  Nothing works.  I thought it was hardware failure at first but a LAN connection to the satellite stopped working too.  I doubt the LAN ports on both would fail.  I'm at a loss as to what it could be.
  • What is the Mfr and model# of the ISP modem the NG router is connected too?
    What is the Mfr and model# of the ethernet switch if one is in the configuration.
    After upgrading to v32, did you factory reset the RBR and RBS and setup from scratch?
    Power OFF all devcies, router and satellite.
    Have one wired PC connected to the back of the RBR. Power it ON. Do you get anything on the network adapter after the RBR comes to ready? Try the different LAN ports in back while its ON.
    Besure to use a good quality known working LAN cable between RBR and PC.
    • Singularity2030's avatar
      Singularity2030
      The modem is an AT&T UVerse Pace 5268AC.  I have temporarily bypassed the switch.  I tried several devices on different ports between the router and satellite, including a PC.  None show a connection.  I did already try disabling the satellites and rebooting.  That did not make a difference.
      • Chuck_M's avatar
        Chuck_M
        Mentor
        Does the router still maintain internet connectivity via wireless?
        I did not see if you tried to factory reset the RBR50 yet... if not, that would be my next step.
