- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
My RBR50 disconnects randomly.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello all,
I am at my wits end. We have replaced my old modem/router combo with a new stand alone modem and stand alone router solution. The hardware is as follows:
Modem: NETGEAR CM500
Router: NETGEAR Orbi RBR50 running firmware V2.3.5.30 on both the router and sattelite.
House Sq Feet: Around 2000
The problem I seem to be having is that the router will randomly just lose connection. I check my modem and I am green across the board but I will have no connection to my PC and the Orbi will be pulsing blue. One time it was pulsing magenta and another time it was just solid magenta. I have done a factory reset on both the router and the sattelite and the problem still persists.
I love the sytem, it is REAL fast for my devices and it is, as others have stated, excellent when it works but for a pricetag over $300 dollars, the term "when it works" should not have to be said.
Any help is appreciated.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: My RBR50 disconnects randomly.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have the ISP check the signal and line quality UP to the modem.
Be sure there are not coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Swap LAN cables between the Orbi RBR and ISP modem.
@Azrael77 wrote:Hello all,
Modem: NETGEAR CM500Router: NETGEAR Orbi RBR50 running firmware V2.3.5.30 on both the router and sattelite.
