go_robot_go's avatar
go_robot_go
Initiate
May 25, 2017
NAT loopback supported by Orbi?
I'm currently a user of the eero mesh wi-fi system, and I've discovered that it doesn't support NAT loopback (in other words, from inside my home network, I cannot reach local resources by using an external address, such as a dyndns URL, but I can reach them just fine if I'm not connected to my home network). I'm looking at the Orbi system as a potential alternative, but I can't find any documentation that confirms whether or not NAT loopback is supported. Can anyone confirm this for me, one way or another?
Thanks in advance!
  • Retired_Member's avatar
    Retired_Member
    NAT Loopback was working for me until the most recent firmware.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Unable to access local resources is a confirmed bug in latest FW. Will be fixed in next official firmware release.
    DarrenM
    • thanks for the confirm darren , was unaware of this as i tested it prior and was working fine
      pete
    • go_robot_go's avatar
      go_robot_go
      Initiate
      Darren, thanks for the response. Is there a timeline on the resolution for this bug, or could you update this thread when the fix is released? I'm eager to replace my wonky eero setup with Orbi, but I'm hesitant to commit to a puchase until I know that this is fixed.
  • Any updates on this? It's been quite a few months since this was posted and I'm still not able to connect to local resources with an external domain name while connected to the Orbi network.
      Retired_Member
      It's been better but intermittent since 1.11.x.
      • clifgriffin's avatar
        clifgriffin
        Hmm, it just spins for me. Any configuration requirements? I'm on the latest firmware. (2.074 I think)
