- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Need to constantly toggle wifi | Dropping | Lag
- Mark as New
- Bookmark
- Subscribe
- Permalink
I live in a small 700 sqft apartment that's divided by concrete walls. I used to have to use an additional router as an AP, but those routers needed an upgrade. Since I'm moving to an new larger 1800 sqft apartment (also concrete walls) I decided on the orbi due to some great reviews and figured 2 satellites would definitely cover the entire apartment. I haven't moved yet, i'm still in the small place and I decide to install the Orbi. I've noticed that I constantly have to toggle my wifi on all my devices to access the internet. Or, for example, when I'm on my laptop the wifi always shows as connected be every couple of minutes when I try to load a website it hangs/lags. If I wait it bit, and try again, it will work. I think maybe the 2 satellites were too close so I turned one satellite off. Didn't seem to help. Then I assumed maybe just the single orbi router might be strong enough to cover the entire apartment, and even one satellite was overlapping too much. However when I turned off the last satellite the entire system lost connection to the internet, which means I assume I cannot just ONLY use the router alone?. I'm not sure what to do here. I purchased this system to improve my internet experience but it seems using Orbi is working against me, and the old router/AP setup was more effective. Please can anyone give me some advice?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Need to constantly toggle wifi | Dropping | Lag
Any other wifi neighbors near by? If so, how many? What channels are they using?
Does just using the router alone exhibit the same thing?
What channels are you using on the Orbi router?
What FW version are you using?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I mean yes I have neighbors that have wifi, but that is normal isn't it? When turned off the satellites the internet connection broke completely, and even though still connected to router I couldn't get online.
I accidently set the wrong region, North America. However I'm using the device in Hong Kong. Could that be the reason? even after a hard reset, and re-setup of the Orbi I could not change the region. Its stuck and greyed out as North America.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Does the model number had a NA at the end of it?
DarrenM
