Orbi WiFi 7 RBE973
Reply
New device vulnerability RBK753
zielin
Tutor
Netgear Armor claims to have detected a vulnerability on one of my devices. See the included screen shot.
The problem is it just says "New device" and I have no way of telling which device on the network it is referring to. When I tap the device icon I briefly see a message saying "Please wait..." then it just returns back to the same screen.
This seems like it would be a great feature if it worked. How do I figure out which device this is referring to?
Message 1 of 5
Guru
Re: New device vulnerability RBK753
Netgear has set up a community forum specifically for the Armor product. Most of the people who watch that forum are more likely to have experience with Armor and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/NETGEAR-Armor/bd-p/en-home-armor
https://www.netgear.com/landings/armor
Good Luck.
Message 2 of 5
CrimpOn
Guru
This looks like a perfect question to post in the community forum for Armor:
My approach would be to look at the Device Manager to see if there is something with a similar description.  The MAC address can be used to determine the manufacturer of the network interface on the device (usually the company that sells the product, but not always).
Message 3 of 5
zielin
Tutor
Thanks @FURRYe38 ! I moved it over.
Message 4 of 5
zielin
Tutor
Thanks for the suggestion @CrimpOn . I forgot to mention I did check the device manager and there is no similary named device. So no way as far as I can tell the figure out the MAC address.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 512 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
